Might have to talk to you about that.
They (Holley) makes a kit for just that to correct the throttle pull. But the new sniper 2 they redesigned to eliminate the need for it. Also it has a new streamlined wiring harness and tuner set up along with blue tooth so you can use ur phone iPad etc for tuning and data logging
Figures I buy one, and then they upgrade it. :pissed:
I'm in the same boat. Only difference is because I install them for other people now I need to get a new set of cables for the laptop and tuning
Went headless after all.
And my gauges are are there also.
What did you do with all the space you freed up in the dash ?
That's a nice setup
For a quick solution I placed an aluminum plate. I still gotta come up with something for directly below the steering column.
Thanks Manic Mechanic.
I was in a veterans day parade one of the oldest in the country this was the 91st annual. 7a0bcd7d23a6a81f4ac32b349029293f.webp 28fa16b5d36aee2c43a108c05ad7299b.webp
At night
Doesn't even look like a Jeep
Not no more, MM. I am not a purist myself. I like restomods. Post a pic of your 74 Formula. And the G8 both with the hoods open.
The heavily modded Cadillac from Kindig designs touches my heart.
Not in the same picture but Yes. I'm also not a purist I like a clean look and admire the work that goes into a job. Here's the G8 I need to look for the formula 2f0e211519cc9caa4b734b0c9e87b5fd.webp aae16db9e38ebb3e581d45ed2e462b7b.webp
I'll have to get to my laptop for pics of the formula with the hood open I don't have any on my phone
LOOK AT THAT. Spec sheet stamp and all. Great collectible. This one does not need modifications.
Someone bring up the orange CJ. Can’t remember where I saw it. Features everything you can think of including a sports manual.
1 of 1111 made in that model and color
Not my Jeep but rooftop work in DC a few sights like the capital Lincoln memorial Jefferson memorial and Washington monument 013633d1632b5892ae9ed0a83e62567b.webp 7fd0fc01f1ae65554c37f88bcb695d7c.webp 520664c5448ca1e86d207c9288fa1830.webp 1b8f685ea693fd891eb9b2985b6350fe.webp
on the TJ-7, just re-wired the dash cluster, was having intermittent gauge failure and no illumination, common failure with the 10 pin connectors on the back to the point they had a recall, I just re-wired with new connectors, all seems good at this point. also replaced ground connection to headlight switch and reinserted a loose wire, was also intermittent.
Did some upgrades to the CJ this last summer. The lightweight flywheel and pressure plate had been on my wishlist for a good while.
    Best for votes
    on specific items
