Might have to talk to you about that.
They (Holley) makes a kit for just that to correct the throttle pull. But the new sniper 2 they redesigned to eliminate the need for it. Also it has a new streamlined wiring harness and tuner set up along with blue tooth so you can use ur phone iPad etc for tuning and data logging
Figures I buy one, and then they upgrade it. :pissed:
I'm in the same boat. Only difference is because I install them for other people now I need to get a new set of cables for the laptop and tuning
What did you do with all the space you freed up in the dash ?
That's a nice setup
Doesn't even look like a Jeep
Not no more, MM. I am not a purist myself. I like restomods. Post a pic of your 74 Formula. And the G8 both with the hoods open.
The heavily modded Cadillac from Kindig designs touches my heart.
I'll have to get to my laptop for pics of the formula with the hood open I don't have any on my phone
LOOK AT THAT. Spec sheet stamp and all. Great collectible. This one does not need modifications.
Someone bring up the orange CJ. Can’t remember where I saw it. Features everything you can think of including a sports manual.
1 of 1111 made in that model and color
on the TJ-7, just re-wired the dash cluster, was having intermittent gauge failure and no illumination, common failure with the 10 pin connectors on the back to the point they had a recall, I just re-wired with new connectors, all seems good at this point. also replaced ground connection to headlight switch and reinserted a loose wire, was also intermittent.
$70.00
  35.0%
