I fixed it just to break it again. I took it out to test it out after replacing both u-joints and straps. I broke my driver side hub trying to get up a rock.
I'm beginning to think this thing does not like me
I didnt do it today but i took pics today of what i did on tuesday.
I took off my old rusty silver hood latches and put on the new black ones that ive had since i bought the jeep.
old ones
New Ones
For a black Jeep, that dude sure looks straight:) Still blocking with 400, lots of blocking, blocking, blocking, more blocking, blocking and blocking....................
replaced and installed new body mounts with 1" body lift from MORE. Had to do repairs on two mounts by welding cracks and reinforcing with steel plate. She,s all better now.
I looked at it.:)
let me guess, the two in the front of the tub??
I just got mine finished this weekend I used the Day star 1" lift mounts. I reinforced with 14 ga. Stainless steel, I think it will take longer to work harden and crack.:cool:
I read this and I was trying to remember when I posted it. I was expecting a senior moment.:confused::confused::confused:
This is kind of a Zen thing, right?
like when you get where you are going, there you are?:D
Lol. Same here! It can't idle poorly, if I don't start it. :chug:
Haha, something like that! I use the same philosophy with my marriage. Don't give an answer to the question, "does this dress make me look fat?" and I don't have to hear how my response was wrong, no matter what I said! Hell, half the time I just turn and walk away. Lol.
I guess it was a mistake to tell her that the dress had nothing to do with her looking fat?:D
Had Flowmaster 40 series muffler and pipe installed. Now it's LOUD! Everyone hears me coming now. If you like close to open header sound go this route.
Finished the new steering column install. Now it's one-hand, no-wander, and no siezing up in tight spots. I didn't know my PS was that good!
Got my baby a strapless bikini.
Quick, if ya wanna see her topless, go to my gallery.
HoooWeee!
I run cherry bombs glass packs on the 70, now that thing is really loud, I do not even use a cross over pipe just headers and the packs then turn them out, Wakes you up when I rev it.
changed the oil in the AMC 232 i6 used 20 w50 to try and keep the oil pressure up which is one problem ive been haveing and dont quite understand what else to do with that. also wanted to get everybodys input on wheel spacers i want to space them an inch or less and plan on using the spacers with seperate lugs. input?
changed the oil in the 232 used 20 w50 to try and keep the oil pressure up which is one problem ive been haveing and dont quite understand what else to do with that. also wanted to get everybodys input on wheel spacers i want to space them an inch or less and plan on using the spacers with seperate lugs. input?
First off that 20w50 oil is for racing. It's for very hot engines. I wouldn't use that on a street vehicle. If your having trouble with your oil pressure you might need a new oil pump.
As for wheel spacers they are good and bad. If you put on bigger tires you may get some rubbing. Wheel spaces will help prevent your tires from rubbing. They also give your jeep a wider, more stable stance. The problem with wheel spacers is that they add more stress to the front ball joints because the wheels are out farther than the manufacturer intended.
Hey, by the way, Wardly258, aren't you new here?
Welcome to the site!:chug:
I made a trip to the local parts store today and bought a distributor cap, rotor, points, and condenser. Plug wires are on order. :chug:
    Best for votes
    on specific items
