hello yall, I used my oba to air all the daily drivers tires and a set of quad tires, I sold today. Then I was board and wanted to go fishing but it was a little windy, so I thought what can I do to the jeep? I took the horns off my 84 chevy parts truck, fixed the contact switch on the horn button. Now the next time I set behind someone at a stop light talking on the phone or just lost in life, I can give them the what for(a hole). Good day:chug:
I replaced the old vintage chevy vandura tail light mod with some 4" round's
as well as replacing ALL of the tail lamp wireing harness.
for what I accomplished it seems like a lot of work, now that it's done.
I got the new off road and LED marker/turn signal lights wired and secured.:)
I got the crappy Crown parking lights to work with a little creative force in the right places.:)
I tied everything in with "keep it clean wiring" weather tight connectors, a 2 wire for the 55W lights and a 4 wire for the LED turn/park lights. If you are looking for a replacement for a connector and not being stock is not a problem or being water/mud resistant is important to you, I recommend them.:)
I like that light bar. It protects the wires and it looks good too.
I ordered a set of lowmax gears for my Dana 300 . I'm in the flat lands of Texas this week, San Antonio. They should be there when I get back home to the mountains and my Jeep.
Nearly got my new dash installed and the newly repainted roll cage is in but not installed.
Removed the factory 8 roll bar and 8 inches of the rear fender
Drained the fuel tank. Was some nastiness in there.
Sent from my SPH-D710 using Tapatalk
I covered all the openings in the empty Dana 300 Transfer Case in prep for painting, first good WX day. I used 1 inch sections of bamboo for washers so I don't have to run the bolts down all the way. RUSTOLEUM gray undercoat and RUSTOLEUM RED for the case. Panels will be metallic silver. No one will likely see it but me!
Took it for its maiden. Voyage today! Needs a handfull of little things finished to make it completely road worthy
Damn...thats a great feeling isnt it!! (assuming it went well)
Bought it ... 1972 CJ5 ...was stored with bad gas and I'm sure some other problems I am yet to find...hahaha:chug:
took the hose to the frame. scrub brush and soap. 3 cans of oven cleaner on the way to get at the gunk. c'mon warm weather
