83 CJ7 350 tbi, TH350, D300 twin sticked & clocked, narrowed Chief D44 Eaton Elocker & Moser shafts, Explorer 8.8 Detroit locker, 410's, RE 4.5" spring lift 1" body lift, 35" Claws, cage tied to frame, Corbeau baja seats, HD tie rod and draglink, u-bolts flipped, custom skid plate and sliders, Warn 9.5ti winch with Amsteel synthetic line
Milled, drilled and taped my flat top knuckles. Should be getting the 44 in the jeep pretty soon now.
I already changed my jeep profile to give me some incentive to get er done.
Good Job Dog...............lookin good on those high mount spindles. Are you going to cut off the old steering arms on those spindles and put everything on top?
Are You using the same tie rod ends or changing those?
Tarry, not sure on the arms, my buddy at TKH fab is trying to talk me into keeping the tie rod hooked to the old arms and using the new high arm for the drag link. He thinks it's a stronger set-up that way (I'm staying SUA) and less stress on the high arms.
I'll be going with bigger rod ends.
Terrry (TKH) has been building jeeps for a living for a long time so he might know what he's talking about.
You have any thoughts?
Dog.........I would be OK with it either way as long as your getting the clearance you want on the tie rod and the drag link without any Bumpsteer.
In some ways that may defeat the purpose of the high steer arm to get the tie rod up and out of the way of things but I would not second guess his wisdom from here.
Mine are a 4 bolt mount system on a purpose built spindle so maybe there is some difference between the two strength wise 3 versus the 4 so I can understand his thinking.
I think you'll be fine.
I used the Moog ES2010R & 2010L they have a 7/8" thread.
1980 cj5 258ci straight 6, 31x10.50's. Partial Teamrush iginition upgrade, MC 2150 Carb. 4.0 head swap, factory header. I call him "Eugene".
Dad's jeep when he raced in the 70's. Cj2 running gear, ford 300 cu in 6 cyl with 3 deuces. Fiberglass model T body and hand laid fiberglass hood. welded 5.38 gears and beer keg fuel tank. see avatar
Wife's: Black 04' Liberty with all the bells and whistles.
didn't exactly do this today, but did finish up my 2150 rebuild and gathered all the parts. Just have to make the adapter arm to attech the bell crank. Then wait on some warmer weather this week to install it.
I need to do the same thing.....I have NO experience at all. Any ideas where to start or how to dumb this process down.....way down. I know the plug in brackets for my turn signal is broken on the fuse box. Am I better off getting a new box and starting over? When the hazards are on, all the lights under the dash blink.
That pattern is pretty standard in the industry..............the adaptors may change depending on the wheel............narrow down the type of new steering wheel your looking for............Go to Grant steering wheels on line and look around.
Your lights that are flashing...........probably a bad Ground wire on that circuit or someone has crossed a wire................no easy fix........just have to look. 12 volts is simple..........one hot wire (+) and one negitive wire (-) in some cases like lights they just run a hot wire+ to the socket then ground the complete fixture. Get a test light.
So the kit will connect to those three bolts and then the wheel bolts to the kit. So I don't need to buy an adapter.
Is a 16" wheel realistic or too big. I don't know what the oem wheel would have been on the CJ5 I had in high school.
Is a 16" wheel realistic or too big. I don't know what the oem wheel would have been on the cj5 I had in high school.
No you will throw out the part that has the 3 bolts.
When you buy your new steering wheel they will ask what vhicle you want to install it on.
You say an '86 Jeep CJ. and they will also sell you this kit:
Notice you get a splined part that fits on your steering wheel column and the steering wheel mounts to that. In other word you replace that part that has the 3 bolts.
I got my MC 2150 on my jeep today. None to soon either, when I removed it there was a puddle of gas in the intake and as Icarried it inside it was dripping. Installed the adapter plate and rebuilt carb. Once the gas got up and it fired right off and idled. Had to fab an L shaped bracket to connect the bell crank.
Street Jeep for snow and ice, still on blocks in the driveway. '73 CJ5, 258 inline six, T18 tranny, Model 20 transfer case, Dana 30/44 w/ 4.27 ratio (soon to be 3.73), original Cutlas hubs, half-cab waiting to be installed. Daily driver is a 20-year-old Mazda pickup.
Sounds like you're measuring an adapter. If so you'll just need a wheel. If I'm not mistaken, a GM adapter is the same as a CJ adapter. (I'll find out for sure when it stops raining and snowing and blowing enough to go out and fuss with mine.)
Pulled the next-to-shortest leaf from each rear spring pack. Didn't change the elevation/angle of the body. Amazed at how much wear on the shackle bolts from running dry thru poly inserts. Me for greaseable shackle bolts forever after! After reattaching everything, I can at last get spring flex when I bounce on the rear bumper!
Replaced the broken/sometimes-functional tail lights with round LED lights: AutoSmart KL-2510 4" Round with Red Lens. I know, it does away with the stock look, but they're a lot brighter than the stock ones.
Also, corrected several wiring issues from a PO in the process, now all the lights work! Back to being street-legal.
