pulled the cheapo batt the PO had installed and won't hold a charge anymore. Worked on the D-ring shackles for the rear bumper and discussed the future front bumper for it. Just generally had a good afternoon with Dad fixing farm equipment and talking Jeeps.
Worked or probably better said reengineered the factory "Sport Bar" and I'm VERY pleased with the results.
installed a new battery... It lives again. Now to tackle that exhaust leak
Wire wheeled my hood hold downs to bare metal going to spray them with Boeshield t-9 and see how long the coating lasts.
What is going on with the power steering? There's a big heavy hose where a simple cap should be.
And the coil mount position?
The hydraulic 1200 winch runs off the PS pump. The winch is at full power at engine idle.
The coil is a high vibration coil that can be mounted in any position. The coil is an MSD 82222
Both you guys had good questions. I had no help at all from the PO so I had to go through everything to find out what was what, and why.
I'm surprised someone hasn't picked up on another item that doesn't "seem" to belong there, it was the second thing I noticed after the PS hose.
Thanks, heard of hydraulic winches, but I'm unfamiliar with how they work.
After building myself a small paint booth complete with vent fan, filter and LED light in the top, I did my first bit of painting. Lucky to have access to a media blaster at work and able to get the parts down to bare metal. Coated several frame mounted brackets including the pictured motor mount bracket with Rust Encapsulator and will follow up with Chassis Black.
Nice! I'll be right over with my bumper project so you can try it out [emoji2]
Wooly
Started it up and let it warm up and charge the battery a little.
Swapped out the passenger side axle ujoint. Replacing rose frozen Ujoints did wonders for the steering. :cool:
Fabricated ..... er bent some pipe, made some brackets to mount the front bar (behind the window), welded pipes to connect the front bar to the exist sport bar. This project is looking more and more better all the time.
We wouldn't know. We haven't seen pics. :poke::poke:
