Started the heater blower upgrade. Broke the heater core. Need to decide if I want the new aluminum one or see if I can get my copper and brass one repaired.
Pulled the body mounts off my '75 CJ5 . They were pretty hard and smashed after 40 years. Will replace with Energy Suspension Polyurethane mounts.
pulled the AMC 258 i6 / 4.2l head yesterday. Dropped the new 4.0 head on today and torqued down.
Done installing my new Borla cat-back. Installation is fairly straightforward. I bought it from 4wheelonline, at a good price. This exhaust is not too loud but sounds nice in 4th gear. Will post a video for the sound next time.
continued with the 4.0 head install.
busted a :censored: bolt off in the head. Going too slow already.
got up this morning and it was a toasty 40 deg. so I drove to work in the CJ.
the drive home with 70 deg and sunshine was the high point of the year, so far.:D
reassembly continues. spent time modifying the power steering bracket to clear the header tube. also discovered that i need a egr for the bottom of the divorced intake, so I can block off the hole.
97 4.0 head. Buddy slung a rod. I got the motor or helping swap it out. Not installing the FI back in it.
Made some small progress with the refurbishment and installation of my Porter & Reed cab.
good looking top. Got any more pics of it?
Tested and cleaned up the coil/wire threads & mounting studs, washers & nuts, and installed on the 2A.
I like the way it looks too.
The way it's constructed makes it very light weight, but it's also a little fragile. The years, and hard use have had an effect, but I think I'll be able to correct those deficiencies.
I do have lots of other pictures, but they show mostly the same thing.
I'm looking forward to when I can take a picture that includes installed doors and windows.
If there's anything in particular you want to see, I'll get the camera out for you.
Z
any would be good. Looks like it's built like a aircraft fuselage.
I win then. Still have the hard top frozen to the driveway. :laugh:
I concede.
I'm never any good at contests, but I'll bet your windshield has glass in it.:)
4 weeks, 1 day, 17 hours, 23 minutes, 35 seconds
