Haven't found the dog yet - but then again I'm on my phone...... I'll check the iPad later this evening
WAIT - Is that it just left of the Rover's DS mirror??
And I bet the local LEO's are sick if 911 calls for a possible B&E LOL
Sent from my gas grille using Tapatalk
Left of the mirror is what I see as the dog.
That's all I could find....
Looks Great!!!
How does she run?
Looks Great!!!
How does she run?
It's running better than it ever has. Good vacuum, responsive throttle, smooth power. Amazing what having the correct size piston rings will do for compression! We might bump up the timing a degree or two, but other than that, I am going to build a new front driveshaft next week and roll some miles on the new engine before heading to Ouray.
What kind of compression are you getting?
135PSI on all 8 cyls after about 100 miles. I expect that number to go up slightly as the rings fully seat.
Looks like it should be a fun weekend!!
007, I suggest a GND wire from the MSD box mounting screw to the fender.
This helps with reduction of RFI.
I got some awesome presents in the mail today, I now have all 4 wheels and tires for the Jeep, and as soon as the spacer kit arrives for my true trac I can measure and order my new moser axle shafts =) and the Jeep will roll on all 4
Progress has happened .. Transfer Case is back in .. seems the body has been installed wrong too far back the high low selector lever hits on the body work
Fuel line leaks like a ...... pulled it out going to have to cut and reflate the steel lines ..
