I have a Novak slave also. Let us know how the Luk is. I think mine is a YJ MC. Looks like yours. Probably same mfg.
Sure thing.
At the time of the drivetrain swap I did my homework to see what worked. Turns out the original MC works just fine.
I think I’m on my 4th if I remember correctly. Rebuilt the original. Tried again but no luck. 2nd lasted quite a while. 3rd quite a while. Then I did the engine change. The 3rd froze up while the Jeep was down for 2 1/2 years . 4th doing ok. Someone said I should try a Wilwood.
I looked in Wilwood’s site and turns out they do have a MC that fits and in three different bore sizes to select from. Guess what…
I’m all ears ?
I am getting it. A significant difference in price but I think it’s worth the investment and will end up with improved pedal leverage. $27 difference in price. Thanks for the tip. :)
My friend told me to get the GS Compact Integral MC 260-15097. Was about $80 a year ago..
I’ll be curious to see if there is improvement. Mine is a little stiff and all the action is close down to the floor.
That one would be the .700 bore, I went for the .750 with a .875 slave cyl bore. I expect a lightened pedal since the stock one still in the vehicle is .864. I have decent pedal performance as is. They say the master to slave displacement ratio should be 1:1 or at most 15% differential. Summit has them for about 78 bucks. I will post up the results after swapping.
Nice. Actually my buddy and I have bled mine while it was on the vehicle at the top side. Glad it worked out. Going to have to get one in the future. Just so I remember what size slave did you have working with this ?
I got the .750 to replace an .864 bore MC. I have an .875 bore slave cyl. The rod end is sold separately and also you’ll need a 3/8 to 7/16 adapter fitting part number BLF23B or equivalent.
If you want clutch disengagement earlier in the pedal travel, match the MC and SC bore sizes.
Where did you end up getting all of it from ?
Summit
Belizean, sir I cannot thank you enough 👌🏼 for the tip. My clutch pedal is as light as that of a Honda Civic. With minor push rod adjustments at both cylinders the clutch engagement is right back where it belongs. Oh yeah!
