Waiting for the flurries to happen.
I changed the oil, while it was out I put a little JBWeld around the alternative drain plug that the PO installed, probably due to a cross thread in the past. For giggles I decided to see if the pan bolts were tight. Maybe that was the source of part of the leak. I was able to tighten them on the side that didn’t have the starter in the way. I don’t know if that helped, lol. Now that the oil is back in, it started dripping again. I didn’t want to pull the starter unless I had to.
Still playing with the shifter, still playing with the body. I’ve been busy so I didn’t have time to get much done.
Looking like a rodent nest you got there.
Interesting. I was trying to say "three zero four stainless" as in the type of steel, but it was auto-changed to AMC 304 . I'm just adding this in case it was confusing.
Interesting. I was trying to say "three zero four stainless" as in the type of steel, but it was auto-changed to AMC 304. I'm just adding this in case it was confusing.
AI doing your thinking for you. :chug: I had that a couple of days ago and had to go back and correct it also.
Yesterday and today I finally found and repaired my (now I know it was 2) exhaust leaks. Yesterday I dropped the right side exhaust back enough so I could weld a leaky weld joint just downstream of the passenger side exhaust manifold. Bolted that back up and the ticking was better but not gone. Google said to use a wet/dry vac and blow into the pipe. It was hissing like crazy on the forward most air tube. All 8 air tubes look like they were welded shut decades ago but this one was cracked at the base and it was blowing straight down (crack hidden from view). I loosened the large bolt head and rotated the tube straight up. I ground the rust away and welded the hole shut.
Also today, I determined all 4 of my rear shackle bushings are toast. I have been fixing many issues causing my unsatisfactory steering over the months. I should have gone in order from the sticky steering thread on here that said address all rear problems first. Anyway, I ordered new bushings and feel that will finally get it to where I want. I used my torch to heat up the spring and frame bushing holders and after they started melting/burning/dripping I pushed them out.
$70.00
  35.0%
