What trans/tranfercase combo to go with?
coldair
Full Time Jeeper
I have a jeep T-18 mated to a Dana 20 ,I also have a Dana 300 that im thinking about installing a ford t18 to. Im trying to decide what Transfer Case would be better.
I have a jeep t18 mated to a dana 20,I also have a dana 300 that im thinking about installing a ford t18 to. Im trying to decide what transfercase would be better.
Thanks IOPort51the 300 will require an adapter to fit the Jeep T-18 which I will assume is a close ratio t-18. the 300 will require an adapter to fit on the Ford t-18 which I will assume is the wide ratio t-18. I say the 300 because it has a lower 4L than the d-20 which would make it a good choice. Just to confuse things Teraflex sells a gear set for the D-20 to lower the 4L well below the D300 stock.
The whole thing boils down to how much money you want to throw at it, doesn't it always?? I don't think there is a wrong move with the options you have chosen.
IMO![]()
Both transfer cases are very strong.Thanks IOPort51
The dana 20 i have already has a tera low kit installed. I am aware of the adapter for the ford t18 to the dana 300 they are costly. I guess i should have included my info (Already have the ford T18) Im trying to decide what transfercase is stronger. Ive seen the tail end of a dana 300 pop off.
Thanks IOPort51
I believe that the earlier D300s had a history of a weaker tailshaft that was shorter than the later ones. Someone out there does make a heavy duty D300 tailshaft kit, maybe Advance Adapters. Anyway with a V8 you will be putting an extreme amount of torque out. This can be calculated by multiplying your engine torque by your low gear ratio(6.32x3xengine torque) any way you will probably come to a number that you should have about 3" diameter axles safely get by so go easy on the right foot.
I’m not sure how much if any difference there is in length between the Ford V8 you have and the AMC motor that came out but if the back of the bell housing sits in the same spot as stock then a T18 with a Dana 300 adaptor and case will not work in your 1974 CJ5 as the rear driveline will be too short. Stick with the Dana 20.[/QUOT]
This will be going in my cj7 not in my 74 cj5. I will be getting rid of my 74 to fund my build on my cj7![]()
