what transmission would have been used in 2wd versions?
PetesPonies
I'm working on another project. I'm building a Model A Ford, but using a 2.0 Pinto engine. I do not want to use a stock Transmission because they are unsynchronized. Some I'm wading through my options. The short transmissions used in Jeep would be nice to use. There is an adapter made to bolt o the 2.0 engine already, however, the T-90 uses a Transfer Case . I don't want a 4wd Model A
So what trans could be used 2wd?? I know there were some 2wd Jeeps ( DJs ), so what trans did they use?? Has to be short like a T90. Thanks
