what transmission would have been used in 2wd versions?
PetesPonies
Mid Atlantic
1964 CJ5
I'm working on another project. I'm building a Model A Ford, but using a 2.0 Pinto engine. I do not want to use a stock Transmission because they are unsynchronized. Some I'm wading through my options. The short transmissions used in Jeep would be nice to use. There is an adapter made to bolt o the 2.0 engine already, however, the T-90 uses a Transfer Case . I don't want a 4wd Model A :) So what Transmission could be used 2wd?? I know there were some 2wd Jeeps ( DJs ), so what Transmission did they use?? Has to be short like a T-90 . Thanks
my '67 DJ-5 2wd used a T-86 behind the 4 cyl. engine. very short and compact. If I wouldn't have let it go with the engine when I sold it, I'd get pics of it for ya.
the few Pintos my buddies and I used to run had transmissions that were anything but short...the shifter on those was waayy back near the output shaft to place them in the right place on the console. Probably about 24" or better in length.
