Whining transfer case.
which Dana t case?
Here is a link that has a diagram of what is turning in each of the 4 positions a Dana 20 can be shifted into
http://www.jeep-club.at/Umbauten/teraflex-umbau-pdfs/neu/low20_install.pdf
If you look into the 2wd high diagram, everything turning is dark, the problem should be in that shaft assembly as it disappears when shifted into 4wd.
I would just buy a general rebuild kit as long as I was redoing one assembly why not do them all.
$35.00
  17.5%
