Why does oil cap have a hose attatched???
VT Woodsman
- Northern Vermont
- 1978 cj7 304 v8 , 4speed which i think is out of a newer cj. Im pretty sure it has a stock transfer case.
It's letting clean air in, unless the pcv is plugged than it will suck oil into the aircleaner.Wait, is the cap taking air in, or letting crankcase fumes out? I need a damn flow chart here.![]()
Thanks for doing that. If it help any, when i took the cap off and soaked it in gas, tons of mud and dirt came off and the spong disinagrated. I was finding dirt coming off from the saturday night fever days.
Interesting how tucked up in the upper portion is foam like a baby air filter.
I was thinking this afternoon I may try to remember to put a manometer on the line in question and see if it is in face positive or negative pressure.
I'l get back to you on this.![]()
thanks for testing it. So am i right in thinking air is sucked in thru the fill cap and air is pushed out thru the pcv . What was amc idea behind this, was it to move fumes out of the crankcase?
