Will these D60 work on a CJ7?
jfmcj7
Hi folks
I friend send me this info on a set of D60 that is for sell about an hour from me. I still have the stock AMC20 and Dana 30 with stock 2.73 gears in my 85 CJ7 . I want to do a re-gear and locker install but know that it will not be cheep nor a good idea on the stock axles.
I have been looking for a good set of Dana 44 for a long time but can't find what I am looking for. Was thinking of getting a set of JK take offs since they are cheep and all over the place, but then I sit with a driver side diff and will need a new Transfer Case witch cost more money.
My main concern is that the JK axles and these will be to wide for the CJ since both will be about 10" wider than the stock wide track axles in the CJ7. Plus the set of D60's has a "king pin" steering set-up and I have no experience with that and don't know it that will even work on a CJ. The price on the set is $4000 obo.
Any input will be great.
Front Dana 60 king pin low pinion passenger side drop. New 35 spline Outers, new king pin bearings, seals, bushings. Warn drive flanges. All new bearings through out the axle. Arb locker, 4.56 genuine spicer gears. We're talking everything has been done! Everything!
Converted to 5 on 5.5 Lug pattern for all you incognito purists. Uses Chevy long side inner shaft and Ford short side inner shaft to get to narrowed 66.75" wms
Rear Dana 60 semi float 5 on 5.5" Lug pattern 35 spline 65.5" wms, spool and 4.56 genuine spicer gears. This is the coveted J4000 gladiator axle.
Everything has been gone through, new axle bearings and seals,brakes, wheel cylinders, everything! Includes park brake cables too!
