Engine 151 Iron Duke 151 CI O-Ring location
CJ51980
Tuscumbia, AL, USA
1980 Jeep CJ5 151 2.5L Iron Duke
I'm in the process of building a 1980 GM 151 CI Iron Duke and the Felpro Gasket kit has a rubber o-ring that has a square cut cross section. I can't find where it it should be installed. It fits perfectly in the Crank hub/Balancer that's behind the crank pulley, underneath the crank bolt. I don't think that's where it goes but not sure.
Thanks for the advice
You don’t think it’s for your thermostat housing…
The gasket kit might include a description of its contents.
Could be, I was gonna check that but haven't gotten to installing the t-housing yet. Sounds like a good idea, thanks.
It did include a description but It wasn't very thorough.
Thanks again, I'll let you know if that was it..👍
