1970s vs 1980s CJ AMC 20
Bent
Featured
Olympic Peninsula
1982 CJ5, 1978 258, T177, Dana 300, AMC 20, Dana 30
What is the tube diameter? CJ AMC20 should be 2 5/8" the FSJ AMC 20 2 3/4" The FSJ 20 is the same size as the FSJ 44.
That bigger one is from a truck. Also has thicker tubes and 1 piece axles.
PB-Does yours have 1 piece axles?
The truck ones were wider than a CJ's.
Looks like my pictures rotated the wrong way. The first picture shows the 1977 CJ5 axle on the left. The second picture shows the 1982 cj5 axle on the left.
They are both narrow track CJ5 axles. Tube diameter is 2.50"
Thicker-I meant as in wall thickness of the tube.
Never seen the 'big' 20 from a CJ. Just the trucks.:confused:
Yup-Looks like a 2-POS axle to me also.
The wall thickness may be thicker on the 1977 axle. I don't have a caliper that will reach down the tube but, the 1977 looks like the tubes are reduced more than the 1982 where they press into the housing. I wonder if the 1980s FSJ axles used the lighter casting or if they continued to get the heavier casting.
Anyone experience tube flex issues with a 1970s vintage axle?
AMC--------
Almost A Car
:D
