1975 CJ5 T18 Transmission
Wally892
Melbourne, Fl
75 CJ5
Recently acquired a 75 CJ5 with 304 T18. I noticed I have a boot under clutch pedal and it looks where a clutch push rod may have been. Is this needed, I am having problems shifting when it is cold, but as it warms up it gets better. Any thoughts. Don't know if work has been done on the clutch, as I do know the tranny was changed at some point to the T18.
Not sure about the boot part, but my T19 is a bit slow when its cold. After a short bit the 80/90w warms up and things get much smoother
If you want better cold shifting you will need to go with a liter transmission oil.
Does your CJ have a mechanical or hydraulic clutch? A mechanical clutch does have a rod going through the firewall to the bell crank.
Probably left over from the mechanical clutch linkage from the factory for that year application.
