Build Thread 1979 Jeep CJ7
Nice pics! Thanks to catering to those of us who like to watch LOL
That was a clean galley - When I opened mine up it was clean, but not quite that clean...... And the new casket install is the only question mark in my head - not totally convinced I got it sealed up tight, and won't know till I run it.
And what the heck is this?? I've been scratching my head and cant come up with any ideas.....
Tub liner looks good! I'll be doing the same in a couple months.
And don't sweat the one piece axles.... the only trouble you MAY run into is having to grind down the retainer ( I think - Mine already had em installed, but in reading threads here, that's usually the only trouble spot.) Oh, and having to remove thrust blocks from the rear differential if you have em. There are plenty of write-ups here - you'll be fine.
Looks like a radio mount to me too. Once you look at the other pictures you can tell it is on the front of the center console.
Wait till I get mine done, I've planned for 5 different radios in the CJ Truck.
I just got done reading a really good article on how to tune your antenna. I only plan to use one radio but want a good one. I have a long whip antenna that came with the Jeep, and for some reason I feel like I just have to use this sucker. I'll have to secure the tip somehow, it won't fit into the garage. So I need to find a clamp of some kind to use.Looks like a radio mount to me too. Once you look at the other pictures you can tell it is on the front of the center console.
On another note PB. I have just ordered my one piece axle kit. I went with the Moser kit. I'll have to find someone with a press to install the bearings and retainer after I get the spacer sized to the housing.
Yeah, after he said it came with radio stuff I figured that's what it was, but I had already asked the stupid question, so I let it ride.... LOL
CB is 'old-school' for sure and I still have one in my Jeep.
TODAY-You're better served with 'Ham'.
73's
K6MTY
Here is an idea for your front bumper mounted high lift. Some grade 8 hardware and steel spacers mounted on the bumper. Just used existing holes in the procomp bumper that were there for lighting etc.
A little advice. I did something similar with my first CJ5 . Bolted my brand new High Lift Jack to the bumper ..... didn't last 12 hours before some SOB took it for himself. Bought a new Jack and used padlocks to secure it. Never lost it again. .... until some years later when another SOB broke into my Trooper II and took that one. But that was in an older time when more folks knew how to use a High Life Jack.Here is an idea for your front bumper mounted high lift. Some grade 8 hardware and steel spacers mounted on the bumper. Just used existing holes in the procomp bumper that were there for lighting etc.
