Build Thread $600 CJ5!
Mouse can nest anywhere! Need big wheels for soft dirt ground...
Yeah, those little buggers can get into everything.
I thought I was sized good enough but some rain last week softened everything up and hanging the engine was too much! :rolleyes:
Rain is a good thang! So is corn, cotton and Jeeps! I'm from the South!
Finally completed the tear down! The spring bolts were basically welded in - it took a lot of pounding, cursing, and some fire to break them loose. Now, I can get to the rust removal and start rebuilding.
Nice work. :chug: What are you going to do with that wonderful front bumper? :wtf:
That thing is ready to take down some doors if needed.
Another weekend and a little more progress. I started tearing down the axles and it looks like I will be going the 1 piece upgrade route. The driver side didn't look too bad, but the passenger side spun at some point. I thought about just replacing the one side axle and hub but it's less than double to just upgrade both sides and be done with it.
So far I have only looked at the outer shafts on the front, not horrible but I will probably just go ahead and replace both with chrome moly and be done with it. Driver's side looks worse than the pass.
Both Warn manual hubs were locked up and full of dirt, those will get a replacement unless I can find a rebuild kit.
Need to get the spindles pulled and figure out what socket to use for the yoke on both front and rear.
Here’s my 41 1/2 year old front IMG_0273.webp axel u joints and spindle bearings from last week. 2 caps were done. Spindle bearings were good but replaced
Those look like the ones that came out of my drive shafts. I'm pretty sure before mine was moved to the hill I picked it up on, it was sitting at the bottom of a drainage.
Here’s my 41 1/2 year old front View attachment 105165axel u joints and spindle bearings from last week. 2 caps were done. Spindle bearings were good but replaced
My driveshaft u-joints looked similar - lots of red. I'm pretty sure that before my jeep was parked on the hill I picked it up from it was at the bottom of a drainage. Everything has been full of dirt. :rolleyes:
