He’s runnin a Wrangler tub. Don’t even get him started on how he squoze a YJ tank into a CJ frame.
Sent from the surface of the sun.... I mean my garage
Shoe horn & can a grease :)
Lol duct tape, bailing wire, zip ties sawz all.....
Sent from Texas, the actual surface of the sun using Tapatalk
So.... did the filler tube swap sides from 82 to 83?
Lol nope, they swapped sides when they went to square headlights, when I was worrying in Afghanistan I was ordering parts and storing them at my sisters house, well a YJ gas tank and skid plate, I really wanted the in tank fuel pump because I intend to have fuel injection I also wanted 20 gallon capacity, unfortunately I did not find any information on the fact that they widened the rear section of the frame when they went to square headlights, the gas tank is 3/4 inch wider than the CJ frame so I decided screw it and widened my frame to YJ width to go with the YJ tank and YJ body I have, I like the filler neck on the drivers side and it’s behind the license plate which looks cleaner to me
Sent from tex mex dinner using Tapatalk
I am familiar with all of the tried and true Technics listed above. Being a country boy from a large family you learn to do with what you have, or do without.
I really would like a 20 gal tank in mine. my 4.0L is fuel injected and I'm sure I'll have to reinvent the plumbing. Any other clearance issues I should know about?
I have seen a few guys since I bought my tank put the in tank fuel pump on the CJ sending unit and drill a hole in the top of it for the wiring and seal the hole up with silicone......
That would be wwwwaaaaaaayyyyy easier than what I did, the CJ 20 gallon tank will hang lower but it’s better than cutting out both rear cross members and welding in new ones after you spread the rails out with a bottle jack
Sent from my kitchen using Tapatalk
The fuel pump on the sending unit is the way i did mine
But will the silicone survive and thrive with gasoline ? Seams like the silicone would deteriorate.
With original sending unit ?
It is the original style sending unit my stock one was junk so while i was in there I replaced it and modified it to accept a fuel pump. I didnt use silicone though I kept the wires stock for the sender. Drilled a hole for a xj sending unit fitting that i had laying around. Also used the the stock plug for the fuel pump wires so i can disconnect it when I service the fuel tank. It was in the middle of winter when I was doing this so I didnt take any picture of the process. But i will have to drop my tank sometime soon so Ill take some Pictures
Well I’m working on the hydroboost, busy these last few days, the Chevy hose I got that goes between the hydr and steering box is a little short since I moved the steering forward so when I get a few minutes I’m going to try to straighten out the hard line ends to get it to fit the steering box
Tapatalk is not working with the site at the moment so no pictures
The adapter needs to push the hydroboost off the firewall by 2 inches and the bolt pattern is 2 7/8x 4.25
I logged out of Tapatalk on my iPad - won’t log back in. But my phone is still hittin the site - for now
Sent from the tropical rain forest of Va.....
HOLY COW I just got the hydroboost working on the Jeep and for some reason there are several Goodyear Dura track prints on the streets in my neighborhood now Wow
HAHAHAHA
Pics or it never happened. No, wait. Videos or it never happened.
HAHAHAHA
Waiting on Tapatalk to get straightened out
LMAO -
So far Tapatalk still works on my phone - but not the iPad.......
Yeah, I’m guessing I’m gonna hafta do this..... dangit
Sent from my desk at work, watching a phenomenal topless day go right by the window....
$20.00
  10.0%
