Well I have a number, I drove my Jeep across the scales this morning and I got 4050 pounds with me and 3/4 tank of fuel
Also hit a huge water puddle and learned that I need to seal the floor better
The mere essence of some sort of sealing would be better LOL
Lol at least some duct tape right? Ya I was surprised at the amount of water that came thru the access hole I cut to get to the Transfer Case shifter mounting bolt
Good thing I didn’t have a passenger they would have been pissed
Or your wife sporting a new pair of shoes......
You had to cut that hole in the floor, or just figured what the heck ?
He bought a new saw.........
More like a cold chisel with a BFH.
lol I was pissed off that day i said to hell with it and cut an access hole in the corner of the tunnel so i could pull the Transfer Case shifters the twin stick set i have has a huge bolt as the pivot pin instead of the factory style
I decided the hell with it, it’s gonna be awhile before I paint might as well enjoy my emblems and seal now
Yea...cause you don't want that new found water source leaking out the tailgate. ;-)
So if you install the twin sticks before the Transfer Case is install, no hole ? I was thinking of maybe doing that, but no way if I need to chop a whole in the tunnel like that.
I rotated my case up so the twin sticks are way up in the tunnel now, would be easier with T case rotated down In stock location
Lol, more so that I’m sick of the tailgate rattle, city won’t let my plant dump our rain water in our parking lot so I will have a big puddle to play in for a while
[emoji23][emoji23]
I bet you can get another set just like em.....
It just looks finished with the lettering [emoji106]
Ok let’s see if this will fix the surging I am getting in the afternoon on my way home,,,,, wix 3/8 inlet/outlet fuel filter with vapor separator and a really old Maroso 1 inch 4 hole plastic spacer under the carb, the initial seat of the pants says the throttle response is better that’s a good start hopefully this fuel :dung: gets better as well
I also pulled the choke flap since it’s not hooked up anyway just to make sure it doesn’t give me issues
Looking at my picture of my intake and carb it’s hard to imagine that a member on this forum sold it to me and shipped them out to Afghanistan so that I could spend my free time rebuilding the carb and gasket matching the intake many moons ago
Time to find out if the tailgate seal holds up lol
Well during the break I was talking with Shum8 about wipers.... specifically intermittent wipers
Interesting enough AMC bought Fords truck switch and the Ford F-AMC 150 /250/350 and Broncos from around 78-91 has an adapter to the switch with a module that converted their wiper motors to intermittent easily identified by the red plug on the back of the wiper switch
So now it’s time for me to find one at a local junkyard soon
https://youtu.be/u9ATHN_bRrI
Well I’m busy tracking down squeaks and rattles, found my stupid hood latches were squeaking so I fixed that :dung: with some 5/16 poly tubing..... got tired of trying to figure out how to compress the spring so I could get the tubing in there so I broke out the big guns lol
Gotta get the extra noises fixed before I worry with panel gaps
