So is that your S H or bleeping Jeeps ? With the shade in the window I'm thinking it is axel time at your place
Bleepin Jeeps I thought it to cool not to share
Usually I can expand the picture and home in to see better but not letting me Is that welded to the race ?
nope, looks like 3/8 flat plate sized perfect to inside of axle tube, welded to all thread with a weight on it and another 3/8 plate on other end to do a different size bearing race, he has to angle plate in behind race, took about 4 taps and that puppy was out, fastest easiest I have ever seen them come out
Guess I would have to see how he gets it in there and see Does sound good and easy
Sorry to hear that !
I shimmed #2 and 8 she sounds much better now still need to shim one of the other cylinders...... I’m still confused on what happened for me to need to shim them tho
I'm not a big engine guy What does that mean ? What are you actually doing to do that ? Is this just a temporary fix ? Or just something to figure out where the problem is ? I'm assuming this is on the crank shaft, but I know what assume can mean sometimes
well I have been thinking about it awhile now and it really only has a few possible causes, worn out rockers and mounts, defective lifters, bad valve job/ sunken valve seats
when I re ringed the motor, I took the heads to a trusted machine shop and had him do a 3 angle valve job with new over size valves and bronze valve guides, I haven’t put a straight edge across the valves to be certain they are even but I assembled the heads and never noticed the amount of variation that I have in the motor
The lifters are new but the cam is used, I could have a problem with the base circle worn down on the cam or the lifters not pumping up correctly the motor runs very smooth and has plenty of power and oil pressure so I do not suspect a damaged cam.... the cheap Chinese lifters I do suspect to be malfunctioning
Idid have worn rockers for sure, those things were toast so I am swapping over to the rockers, mounts, bridges and push rods from the spare motor to eliminate that problem
I think I will ride with the shims for awhile
when I go to fix this issue right I want a new cam, lifters, valve springs, locks and retainers, that will eliminate all the old motor parts and should hopefully solve the problem for good
so with the old valve rockers they were loose over the top of the valve tips, as the cam pushed the push rod up and actuated the rocker it would strike the top of the valve and cause a tap
hydrulic lifters have a piston in the center of them that takes the oil pressure from the motor to push the pushrod up to fill the gap between the rocker top and valve tip... this allows a motor to run til rebuild with out having to adjust the rockers like the old solid lifter motors
when you are building a new custom motor and cannot use stock push rods you are supposed to size a push rod so that with the valve fully closed and the lifter fully down off the ramp the push rod should push that piston in the center of the lifter down x amount so it can pump up as parts get wear on them
I have a completely stock motor I should be able to use all stock parts
I keep looking at this cam kit that would make sure it’s not the cam or lifters
Man, you can’t catch a break and it’s not small items either
lol, nope but that’s what I’m down to. all the big stuff done time to tidy up the small stuff
This should be interesting...... wish me luck I’m keeping my cracked windshield for now :0
$20.00
  10.0%
