    Thank you for your support!
Oh dang I was just corrected 15463
Well that used to be a freshly rebuilt F script T84
Looks like it has done some submarining.
Oh, man...... think a shot of WD-40 will fix it?
I’ve got it soaked with WD40 but that ain’t gonna do anything, I’m going to try soaking it in some evapo rust for awhile and see what it looks like
I was able to pull the t case and Transmission out of the frame last night, tcase was full of new oil, hopefully will have them separated tonight
That is not one I'm familiar with. Even my common T-176 / 7 there were a couple of only chinee parts available. Are you going to be able to find what you need ?
I need to find a sarcasm font for stuff like that.......
I think you already have that loaded in. Just saying
Sweet, I have neutral 2nd and 3rd gears back in the Transmission
Hard to imagine this Transfer Case was attached to that Transmission
Bonus… looks like the front and rear axle were sand blasted, rebuilt, and rattle canned black
To bad everything else is :dung: lol
Definitely gonna be a sweet project
I’m on the hunt for a flathead motor and bell housing if you guys know of one let me know, I decided since it’s a January 42 Jeep it’s going back factory stock
Looks like there is still some metal left on that body. What axles and Transfer Case ?
It has the correct front Dana 25 with no lockouts and correct full float Dana 27 rear as well as a T84 Transmission which is correct type but the one I have is an “F” script Ford GPW Transmission , I also have the correct 3/4” intermediate shaft Dana 18 Transfer Case , the frame looks to be a 46 and up willys CJ frame that was modified for 60s CJ manual steering, that’s gonna get cut off
99% of the metal is intact, but nothing is straight so I will be spending all my time with a hammer and dolly
Your sheet metal looks like mine when I got it. I still believe mine was used to haul cattle...... in it and on it.
Gonna scrounge up a pedestal and .30 cal for it?
Wouldn’t be correct without one
I'll bring the lead.
Yeah some seats and elbow grease as ole grampa would say and you got a down hill roller
3 weeks, 2 days, 10 hours, 13 minutes, 12 seconds
