AMC 20 Axle Woes. Need Help/Advice
cj rob
- tallahassee
- 1982 cj7 with vortec 5.3, sittin on a 4.5" lift and 35's. This thing is nasty strong.
I just did the moser one piece swap on mine. Had to do it twice but that is another story. What I found was the previous owner did not put the brake backing plates in it (has disc conversion) which allowed the bearing to move in the tube. The moser set up uses a spacer ring that makes the bearing, after pressed on, protrude about .003" . When you put the backing plate on, it preload the bearing against the spacer ring and locks everything in place.Lipstick on a pig-
Hope this helps.
