Are these used axles beyond recovery?
- Media
- 1
- california
- 1965 CJ-5 Buick V6 Ford T-18 4-Speed Spicer 20/18,Warn Overdrive Dana 30 & 44 w/Powr-Lok posi / both,4.27 gears 33" tires.
I rarely argue with you Tarry , butfrom 2.73 to 3.73 is a substantial jump. Your gonna feel that easily. I think 4.10 is the right gearing for 33s but axle replacement is alot easier than buying the tools and having the knowledge to set up your regear. 3.73 isnt a bad ratio for 33s.
The second point is that your not agreeing with Lumpy. He wants nothing to do with the AMC20 . The OP has a chance to get a set of axles with 3.73 gearing and the rear is a Dana 44 . Its a better packge with the right carriers already. Will he want to go up in tire size later? Will hewant ultra low gears for rock crawling? That Im not sure on. Im sure he'll let us know before blood is spilled though.![]()
Pete ..........I didn't not know we were arguing? But we can if you like!
Re-read LG's post he clearly states ...."Use your axles and build from there. Moser 1 piece axles are a MUST have! You'll need 2, LSD carriers, 2 R&P's with install kits."
I don't see where buying someone else's junk that more than likely will require more parts & cost's just to bring it up to Speed is a great choice!
The difference in crawl ratio's between the 2.73 (28.83:1) and the 3.73 (39.38:1 ) is 11 points, in either case , hardly anything to write home about.........
But the real crust of my points were centered around telling this guy to figure out "First" what is he trying to accomplish?..........that in itself will tell everyone which way is the best approach!
