The oil pressure gauge on my new (to me) CJ7 goes crazy when the engine is running. It goes from 0 - pegged almost faster than you can see it. I'm thinking that it's either a short in the wire or a bad sender. Just wanted to see what you guys thought.
Mine could be "steered" by the dimmer-switch of the lights...
While the gauge- lights were bright i had no oil-pressure. While dimming the light
The oil-pressure slowly increased.
The solution was (like almost always) a bad ground of the oil-pressure gauge.
1979 Jeep CJ5 with '72 304 V8, MC2100carb,T150 trans, AMC20 rear diff with locker, Dana 30 front diff, Dana 20 Tr Case, Procomp Springs, Gabriel Ultra shocks.
Other thing i had was the fuel-gauge jumping fast to the full position immediately after ignition on.
Also (!) was a bad ground inside the speedometer gauge.
As i read in a famous post here about gauges: check your groud
Got the oil pressure gauge fixed. Turned out the wire coming off the sender was barely connected. Pulled it off and pinched the connector a little bit with my needle nose and voila, good as new.
