Clutch? Spring? Question...???
228jeeper
Ocean Springs, MS
86 CJ-7, 258, Desmogged, 4 speed T-176, Carter-Weber 2731, headers (no idea what kind), K&N Air Cleaner. Everything else stock as near as I can tell
Jeep was running fine when I was downshifting into 2nd to make a turn and I heard something sound like it snapped. Jeep then would shift into first but not without force or grinding. Happened to be close to home so just limped on in. Looked underneath and found this spring hanging. See pic. It seems to be broken off on one end, but I cant find where it would connect to and quite honestly do not know where or which direction it would go or even what it is called. Any help would be appreciated. Thanks.
OK, could this be what is called an outer clutch fork return spring? I have found an animal by this name on the web, but it looks nothing like the one on the jeep. I can see the hole on the housing of the clutch fork where the current one sits now, but where does the other end go? there is a hole rearward and upward on the bell housing. Is this where that end of the spring goes? Thanks
You can check for the presence of the ball by prying out the rubber clutch fork boot and getting a flashlight in there. It will be pretty obvious. If the fork is sloppy, you may have lost the ball.
Busa, from what vantage point is this pic taken, meaning facing the front of the vehicle, or facing the rear? Whick way dos the spring go, towards the front or back? I think I may have lost the ball as well. I apologize if I dont call these things by the right name, but looking towards the rear from underneath, there is a threaded rod that mates to the indention on the fork. Looks like this is where the ball would go. Can this threaded rod be loosened and a new ball put in there, provided the ball itself can be purchased? Thanks.
I see what you mean. I was looking towards the back of the jeep, not the front. Now I have to get a new spring and find where it connects to. Assuming everything else is ok, should this get me back running? And what exactly does this spring do? The spring that was on there was hooked to a hole in the fork towards the end of it, on the outside of the linkage. I have no idea where it was hooked on the other end. BTW, the other two pics you sent did not come through.:)
Busa, thanks for the info. I did some other searching and found some good pics and descriptions. In your last two posts, the pics didnt come through I will locate a spring and try to replace it. Any tips for putting that little bugger on? Thanks
Busa here is an update for you. I went to the local auto zone and picked up a pack of assorted springs, 6 bucks and change. I took the one that was closest in size and stiffness and fabbed it to fit as you showed me. Still does not work right. I got to looking at the spring that came out of there and took notice of the shape it was bent in. It had to go to a hole in the skid plate kind of rearward and upward of the clutch fork. So I fabbed it again to go to this hole and would you believe it works like a charm. Even shifts a bit smoother than before. Any idea why this could be so? Thanks.
I see in your pics now that it should be pulled forward, but when I put the spring on like shown, it will not go into gear at all. But when I pull it upward and rearward it works like a charm. Any idea why that is?
Could my linkage need to be adjusted rearward to achieve the same effect?
