Crossmember replacement help
Gclyne
- Indiana
- 1978 CJ5, 258 I6, T-18a, Dana 30 with AMC 20. 4 inch lift, 1 inch shackle lift, 1 inch body mount lift, 2 inch spring lift. 33" all terrains. Daily driver, 60k miles. :)
I am about to replace the cross member on my 78 CJ5 , the PO added a bumper with a hitch and did not connect it to the frame, only connected to the crossmember. Some time or another it was stepped on to hard or was hit and the crossmember sits a little bit to low on one side.
I figured replacing it wouldn't be a big deal since it's a fairly cheap part at $60.
I need help on how to install it the easiest way. I want avoid removing the gas tank if at all possible. Does anyone have expierience with this? Thanks in advance!
