D300 shaft seal
id check the valve cover for a leak
If you run a T4/T5 tranny, you had best run syn 75W-90 gear oil.
You might check that advice sir. 75w-90 or 80w-90 in a GL5 flavor is a no-no. Reason is GL5 has phosphorus and sulfur (exteme pressure agents) that eat brass synchros inside the transmission. YES the T-4 has brass synchros.
For a T-4 for sure, you need synchromesh fluid. T-5 runs ATF last I heard.
Any transmission that has brass synchros, never run 80w-90 rear diff type lube. Don't care how synthetic it is or claims to be. That relates to the base oil, not the additive pack.
slomo
slomo
Mine works like the day I drove away from the dealership with over 236,500 miles, along with the original clutch also. Hate to go to synchromesh, probably a month later I would be saying it had gone to hell![]()
336K miles on a clutch
Was it ever shifted?
236K. Don't want to take that much credit. What can I say. 84 was a good year!
