Dana 300 oil seal replacement help
jeremy5780
1985 CJ7 with the Dana 300 t case, It has developed a pretty good leak from the front output shaft. The repair manual says i can replace the oil seal with the t case left installed in the jeep. After reading the manual it states i need a few special tools such as tool AMC C-3281 holder tool to remove the nut from the output shaft. Then a puller to remove the yoke, then use the puller to remove the felt seal, the oil seal and the gasket. Then I need tool amc W-143 a driver to re install the new seal. Has anyone done this job before? If so what can you tell me about it if anything?
. Next I put a little grease on the new seal and lightly tapped it in once it was flush I got a piece of 2" pvc pipe and finished tapping it in until it was seated. I re installed the output shaft and nut and washer then put the drive shaft back together and refilled the T case with new fluid. re install the skid plate and done! Job took me less than 2 hours and I did NOT remove the T case!
