Dieseling
Germy
Full Time Jeeper
- Cincinnati, Ohio
- 1985 jeep cj7 360 20 rear and 30 front w/warn lockers 5 speed tranny,
1971 dodge dart built 318
Runs Grreat!!!!
out of it, hoping that the hei just doesn't have enough powerNot necessarily. It might have a weak spark with low voltage. Weak spark, coupled with possibly fuel fowled plugs would get you only a sputter if anything. Have your plugs dried out? You might have to try taking your battery to a Pep Boys/Advance/Auto Zone to have them charge it for you. My charger couldn't handle putting a decent charge on an Optima, either.
When you say you can get a sputter when you stand on the pedal, that still leads me to believe that the plugs are fuel fowled. Think about it -- throttle floored = throttle blades wide open = letting as much air into the cylinders as possible (NOT as much fuel as possible). I think your plugs are still wet.
Shouldn't be, once they are dry they should fire again.Plugs bad?
outWe use essential cookies to make this site work, and optional cookies to enhance your experience.
