Diff oil
Diff oil
driver007
Canada
1981 cj5 304 v8, 300 Dana,model 30 Dana and model 20 AMC rear end
What should I run for a diff oil in a open diff? Is there a good better best or any additives that a person should run. In my last I think I ran 80-90
80w90 is sufficient for an open diff. Additives really aren't necessary unless you have a Limited slip.
I see you are in Canada.
I like synthetic 80/90 in the cold. Better mileage and doesn't need to warm up.
I dump it in the Spring and run regular gearlube during the Summer. It's cheaper. Mine spends a lot of time under water and needs to be changed often.
No snow around here this year. Lucky you. Snow is like running in clean mud with no pressure washing afterwards.
Haven't even pulled the cover on the snowmobile yet.
