Differential gear pattern?
Hedgehog
Always Off-Roading Jeeper
- Tucson/Marana Arizona
- -1975 Jeep CJ5, 360 V8, Headers, Duel Exhaust,T15 transmission, D-20 Transfer case, Twin Stick Conversion, Warn 8274 Winch
That makes more sense to me.
Gandpoint - actually has the closest pattern to mine, I can see I'm close. Deeper = higher pinion.
H-pattern - this is probably the most confusing with a WIDE range of acceptable gear patterns and mine does fall in their group of "Acceptable" patterns. Again with the possible exception of mine needing to be deeper.
The bearing puller I have was barrowed form a friend, it is a great tool. It works great on regular bearings, I'm not so sure about the pinion bearing though. We will see.
