Doing front disc brake conversion issue: one brake pad tight squeezed between rotor
76cj7chick
Old Time Jeeper
- Solutions
- 1
- WA
- 1976 CJ7 Jeep with a engine/tranny/wiring harness out of a 1988 s10 blazer 4.3l v6 with th700r4 automatic tranny and a cj7 Dana 300 transfer case with Novak adapter.
Complete wiring harness from the s10 blazer. Painted with HOT PINK Pearl paint with standard sized metallic halographic pink flakes. Painted by me -a newb. New rear, front and side three wire LED lights, New parts, new custom dash-by me And a lot of guidance from fellow jeepers and lots of prayers etc.... :p
Hey guys I am in the middle of converting my front drum brakes to disc brakes and I am almost finished with the driver side but when I try to install the caliper on the bracket with pads I can't get the loaded caliper on due to the one pad is too tight of a fit and won't let the rotor turn and won't go on)
The other (outer) pad has extra room.
I can get everything to fit if I don't install the one pad that is too tight.
To get the other pad to fit, should I grind down the one pad, install a spacer between the caliper bracket and rotor (if yes, which spacer) or bend back the caliper bracket to allow more even space for the pads?
Or am I not installing correctly? (I believe I am, but may as well ask, just in case). Do the slider pins sit on outside or inner of the caliper?
Thanks. Hope to get the brakes done soon.
