drive shaft
johncarter0488
I am restoring a 78 CJ5 and have a little concern. So i took off the body lift and put on a 4 inch rough country lift kit. My CJ at the moment does not have the body on so the suspension is pretty much unloaded, even sitting on the ground. I put everything on, following directions to the T and guess what- driveshaft is 1/4 short. Now, i understand that once everything is back on the jeep it should reach. What im worried about or dont understand is that- if my suspension for whatever reason became fully unloaded, isnt that going to create some problems? I called rough country and they said not to worry about it. I have the stock spicer 20 Tcase lowered and my AMC axle pinion angle has 8 degree shims in. Does this sound funny to anyone? Thanks, FNG.
