Drivers side wiper broke, help please?
santa
Ohio
'77 CJ7 With 1984 body
Straight six 258
One piece Mosier rear axle
31" tires on 10" rims ( I believe)
Hard top
Full steel doors
Ladies and Gentleman,
I did a search and read quite a bit on windshield wiper repair. However, I cannot find anything that relates to my situation.
When operated my drivers side blade will go one or two strokes and then flop down past the windshield frame towards the drivers side. I thought that it was the splines in the wiper pivot were worn out, but after removing it, they are not. Is there any particular reason for it doing this? Any help is appreciated! Getting hard to see with the snow and ice:D!
If there is no defect in the outer arm connection then the next reasonable place to look is the linkage inside the windsheild frame, the 2 oval plastic plugs will give access to the linkage although not sure if you have a dash pad but you may need to remove it.
Yes, I am convinced you have the same problem I had.
When parts 5 and 9 become too strait the motor can't pull the linkage back. At first I though I had to move the motor. But there isn't much movement to the motor. Then I realised the windshield was bent where the wiper pivot was mounted.
Remove the plastic plugs in the windshild frame to watch the linkages and the pivot. I think you will see the pivot goes too far to one side. I hope I am describing this properly. Maybe I should make a drawing to show you.
Here's how I fixed it.
I removed the pivot (part 9) out of the windshield frame. I then installed a large bolt where the wiper pivot should be. I had large nuts clamping this bolt in place of the pivot. Becasue of the tilt of the windshield this bolt point upward. But in my case it also tilted to the right. It sounds like you will see it tilt to the left. With this bolt clamping tightly onto the windshield frame force the bolt so it is not pointing to the right or the left. This will straiten the windshield frame back to the way it should be.
If you do this right you will see the linkage no longer going to the extreme anymore.
I hope this helps.
Thank you Busa! I understand completely. :)
While we are on the subject. In the parts diagram posted by Busa, what is part #12? Is that the wiper fluid pump? If so, where is that supposed to be located? I do not have one and was wondering where it goes.
Got it fixed!!! Thanks to everyone for their help.
It was exactly how Busa described the problem. Took it apart and tweaked the hole and it works now. I hope it does not contract back and bind, but time will tell. Thanks again.
