Finding the right oil pan
PanhandleJeepin
My experience is rather low with vehicle maintenance but I wanted to learn so I bought a 83 CJ7 with an AMC straight 6 to tinker with and learn the ropes. I recently replaced the rear main seal and noticed the oil pan was missing 3 bolts on the driver side. Upon further inspection I realized that the holes on the pan didn't line up with the holes on the engine. Only 3 all the others are perfect. I had ordered the Fel-pro blue rubber gasket for the AMC 258 i6 / 4.2l and it lined up with the pan. Just out of curiosity I picked up the Fel-pro cork gasket which came with 2 different pieces for that side, one fits pan and one fits engine. I figure it is one of two things, the 258 has some years with a slightly different bolt pattern or it's not a 258. The box for the cork gasket says it fits AMC 232 i6 , 242(4.0l), and 258(4.2l). The only markings I can find on the engine is a metal tag just below the alternator (pic attached), but I have yet to find any information. I have read that it may be hard to tell the difference visually and from the 82 CJ7 258 my friend has the engine is identical (with the exception of the power brakes). I'm hoping someone on here has experienced or heard of this before and can save me any more headache. Any tricks you may have for this amateur to get the correct part would be greatly appreciated.
