Finding the right oil pan
Pensacola, FL
83 CJ7, 258, T5
Does this appear to be an aftermarket pan? I would think you could even drill and tap some new holes in the block if need be.
:ww: :dbanana: :banana:
If aftermarket(Crown or Omix) I'm surprised it's only 3.:rolleyes:
How far off is this hole alignment? Can you use a round file and elongate the pan's holes some?
At first I thought it was probably the pan, but when the fel-pro one piece rubber gasket fit the pan perfectly I started to wonder. Then when the 4 piece cork gasket had 2 separate pieces for that side, one fitting the engine and one fitting the pan I started looking more into what pan the cork gasket was designed to fit. Since I get blank stares at all the auto parts stores when I ask about it I knew it wasn't going to be easy. I could probably order a pan for each of the engines listed on the box and return the ones that don't work but don't really want to do that. I was able to hold the pan in place with the 4 corner bolts and get a punch in from the top to mark the pan and then drill it out. Two of the holes I drilled are within a quarter of an inch from original and one is right up against the original. I'm thinking I can fill the original holes with some JB weld or some gasket maker to keep it from leaking.
Lot easier to re-drill the pan.;)
Some people just like a good challenge:)
Engine Oil
