First snag, rearend woes
huntingbigun
Dover, FL
1982 CJ7 258 Hard Top T5 Dana 300,
2011 F250 diesel 4X4 ,
2011 Diamondback Airboat with 800 Hsp LS7 Supercharged Mast Motor
The bearing were installed backwards by PO, new Yukon parts fit the shafts fine. Putting the trac loc clutches in was not too bad so on to front locker and hopefully no more surprises. So if anyone had the Genuine axle kits Yukon bearings, seals and spacer fit fine. I did get the oringal install instructions from the PO and shows the bearing going the other way with the big end towards the pumpkin, PO still had paperwork 1999:D
The AMC20 is more complicated than your run of the mill c-clip.
Decent cj rear when there all done up .
Are you gona use a hi performance grease like Lumax lx 1909 or 1914 ive been using there stuff latly its pretty good..
Hey if you what to sell your extra sparton let me know im doing up a 1998 20 from a chero for my YJ
The amc 20 is more complicated than your run of the mill c-clip.
Thanks but I sent it back, Randy's Pinon says it happens all the time :D
