Gear Oil
Gear Oil
Tin Medic
Ft. Carson
85 CJ-7 Renegade:
Fuel Injected 4.2L I6/T5/D300
D30 with ARB Air Locker, AMC 20 w/Posi
Warn 8000 LB winch
VIAIR Onboard Air System
33x12.5x15 Goodyear MT/R's
Kenwood head Unit
Hella E-Code Lights
Can I use the same gear oil in an air locker up front, a posi unit in the rear and my T-5 tranny? :confused:
You should be able to use the same in all. Add a bottle of friction modifier for the rear posi.
I tought the T-5 used automatic tranny fluid which helped it shift smoother. The diffs oil is to heavy.
Dexron III for the T-5 ...at least
Oh no the T-5 oil debate again.:eek: The manual says Dexron automatic Transmission fluid. some say 70W gear oil. Check out this link:http://www.jeep-cj.com/forums/f2/t5-trans-fluid-what-get-3528/
What type of Limited slip do you have? A clutch type Limited slip such as an Auburn or Trac-Lok needs a Limited slip additive.
A gear type Limited slip such as a Trutrac does not use an additive.
Check out this link for more info:http://www.jeep-cj.com/forums/f105/lockers-limited-slip-differentials-12434/
I will be opening up both diff's to check everything out. On the rear I believe it is a Trac-Lock but wont be sure until I open it. I might give the syncromesh oil a try in the T-5 and see how that works. So 90W for both diff's with an additive for the rear if it's a Trac-Lock.
I will be opening up both diff's to check everything out. On the rear I believe it is a Trac-Lock but wont be sure until I open it. I might give the syncromesh oil a try in the T5 and see how that works. So 90W for both diff's with an additive for the rear if it's a Trac-Lock.
Correct. :chug:
Engine Oil
