Has my jeep been nuttered?
jeremy5780
South west FL
1985 cj7
I have been doing a lot of reading and I'm just not 100% sure if my 85 CJ7 has been nuttered by the PO. I have 4 wire's coming off my dizzy a brown, black, and red which go from the box on the side of the dizzy to the inside of the dizzy. Then there is a green wire coming out of the box on the side of the dizzy and this wire is connected by the blue butt connector to a fat red wire which runs to the back of the fuse panel then to? There is no ICM on the fender or fire wall I have searched. there is a computer inside the dash behind the glove box.
You have an hei distributor, or high energy ignition. The coil is on top and the ignition module is inside. So the answer to you question is yes it has been nuttered.
$45.00
  22.5%
