Engine Is this the correct 2100?
NY
85 CJ7 4.2l, T5, Dana 300, Dana 30 front, AMC20 rear. 4.56 gears
Only issue is most of these are made in China and aren't really that great. I've installed a few and they really only lasted about a year or so. On top of that yours should be a 1.08 venturi but the aftermarket units don't measure up correctly
Key words, "2100 -style". It's a knock off.
I would attempt a rebuild. What parts are you missing?
Sigh. I have some leakage around the throttle shafts too. I’m not exactly sure how to stop that.
They sell replacement shaft plastic or bronze bushings and just about everything else. Remember, this was the standard 2bbl ford carb also. ;)
*********** Link below ********
Or you can step up and put EFI on it. There are some great options from Holley and ACES
Ethanol kills carbs
Depending on what you need I have a small pile of 2100s here I might be able to get you parts
Oh, that’s interesting! I thought all the 2100s had a screw on fuel filter on the front!
My '78 Jeep came with a Holly 4412-2 2bbl carb. Because the Holley was never approved for use in CA, even though it passed the emissions test, I was forced to put an MC2100 back on it, per CA regulations. Earlier this year (2025), I could find no new, rebuilt or rebuildable MC2100s anywhere. So, after talking with the friendly folks at UREMCO, I purchased their rebuilt Chinese version. So far, my AMC 304 V8 is running well. I would advise, should you go this route, however, that you pull of the top of the carb and check the float setting, at the very least. On mine, the float was way off.
My '78 Jeep came with a Holly 4412-2 2bbl carb. Because the Holley was never approved for use in CA, even though it passed the emissions test, I was forced to put an MC2100 back on it, per CA regulations. Earlier this year (2025), I could find no new, rebuilt or rebuildable MC2100s anywhere. So, after talking with the friendly folks at UREMCO, I purchased their rebuilt Chinese version. So far, my 304 V8 is running well. I would advise, should you go this route, however, that you pull of the top of the carb and check the float setting, at the very least. On mine, the float was way off.
Good info and I am glad it is working for you.
I think I’ll be fooling with my 2100 for a bit more, but if I do swap it, do you know which Uremco you ordered?
Yes, it's a 10-10047. I did not mention previously, that I also bought two metering jets from mikescarb.com (120-4-49). The two, plus shipping, cost all of $15. The jets that came with the new carb were not marked, so I bought US-made jets that were marked. I wanted to be sure I had the right jets for my AMC 304 engine. Mike's Carbs has jets, gaskets, spacers, etc. I also added an electric choke from Mike's.
