J10 driveline to 72 CJ5
cbrown1573
aurora, colorado
74 CJ5 Renegage, totaly stock
72 CJ5 Renegade, built for rock crawling
07 JK Rubicon, built for rock crawling
04 Chevy Silverado tow travel trailer & jeeps
07 Chevy Impala SS
08 Yamaha Roadliner, 113 cubic inch v twin
I have a 72 CJ5 with a AMC 304 , 3speed, and Dana 20 Transfer Case . The engine won't hold oil pressure when it warms up. I have found a 360, T-18 Transmission and 300 dana transfer case in a 1981 J10 pickup. Does anyone know if I can transplant this complete drive train? My concern is that advance adapters has a kit for the dana 20 case with a "shorter" transmission shaft. Has anyone heard of this transplant before?
Thanks for the input
the j-10 drive train is several inches longer than what you have now. In a CJ5 you would very possibly end up with a rear shaft that would not allow a decent amount of travel.
I have heard of people talking about it but never knew anybody that was successful at it. perhaps in a CJ7 .
For what you are about to get into a rebuilt AMC 304 or a 360 swap is the most practical. not that practical enters into the whole project. There are t-18s and there are t-18s and there are j-10 bell housings and cj bell housings and they just don't mix and match that well.
to fit the T-18 to the cj bell to make it short enough to make it even possible to fit in a cj you have to swap the input shaft for a shorter one. This is not a off the shelf item but rather a after market custom job.
For about the same money you can buy a Ford truck t-18 with a lower granny and an adapter from Novak to mate the Transfer Case . And you still end up with a new drive shaft front and rear.:cool:
I have a 72 CJ5 with a 304, 3speed, and dana 20 transfer case. The engine won't hold oil pressure when it warms up. I have found a 360, t18 transmission and 300 dana transfer case in a 1981 J10 pickup. Does anyone know if I can transplant this complete drive train? My concern is that advance adapters has a kit for the dana 20 case with a "shorter" transmission shaft. Has anyone heard of this transplant before?
Thanks for the info. If I were to just buy the 360 engine, would my T-150 bell housing fit? Would I need to buy the clutch that is currently on the 360? The engine is already rebuilt and it currently has a new clutch. Would this be a bolt up?
Thanks,
Curtis
It should fit your bell with no problem. You have to have the flywheel is is balanced for the engine and is specific to the 360. may as well get the clutch as well.
the AMC 304 and the 360 are the same block just different size holes for the pistons.:D
Curtis
The above listed posts will cover the motor Transmission T/C swap. Your rear drive shaft will be to short. As far as the axles go you will need to outboard the front and install new spring perches on the rear. If you do decide to use the motor, trans and T/C for the swap from the J-10 you will be able to use the front axle that came with the J-10 since its on the proper side. Most CJ builder dont like it because its not normal for a CJ.
I am installing a 360/T-18b(waggy or J-10) and Dana 20 TC in my 7 but it will also be stretched quite a bit.. I think it will be well over 110'' so the drive shaft angle will be good.
Another option to go with the 360 is a 727 trans .. the Dana 300 will bolt right to the back of it. you need atleast 4" of lift to pull that combo off. Have you looked at checking the clearance in your oil pump? Bulltear sells a steel mid plate and thinner gaskets to help with pump wear. I got a standard midplate plus a thinner gasket today for around $35 shipped. If ti doesnt help the AMC 304 you can reuse it on the 360.
Oh and if it's all stock then the j-10 has a dana 20 T/C not a dana 300.
And if you were to get crazy and swap the axles they are ridiculously wider then a AMC from a CJ. I put a set of J-10 axles under a CJ and almost the whole tire stick out from under it.
Thanks for all the great input. I'm going to just get the engine and clutch, plan to put them in as it should be a bolt up. Plan to take your advise and find a ford T-18 and keep the Dana 20 . Next year....
Thanks,
Curtis
:notworthy:
you can take the adapter off of that Transmission and put a short shaft in it and it will bolt to a 4spd cj bellhousing which would make it about the same length as a T-18 /Dana 20
