Jeep-CJ Public Service Announcement
Petescj
Member
Lifetime Supporter
Featured
PA
1982 CJ-7 258 / T-18 / Dana 300 31 in All Terrains.
1978 CJ-7 304 / TH 400 / Quadratrac 32 in Mud Terrains
I've learned the hard way that a manual Transmission left in the jeep with out some kind of top over it will have water run down the shift handle and fill the case up.. You pick it up thinking you scored and when you pop the cover its half full of rusty gears.. I pull covers from every thing I buy or sell.. Want to buy an axle from me?? It will be on stands with the cover off when you get here just to verify condition and gears are not damaged.
Want to sell me some axles? Ill show up with my tools, jack stands and drain pan to pull the covers. If I can't pull the covers I'm leaving with out the axle.
Even when buying a motor I'd like to pull the valve covers, intake and oil pan.
Looks like my 20 as well. I'd rather smell a pile of dog turd than that nasty gear oil.
:eek:
Yep, keeping your fluids changed is cheap insurance.
I've learned the hard way that a manual transmission left in the jeep with out some kind of top over it will have water run down the shift handle and fill the case up.
A-A-A-A-K! I've got one of those! Sheesh--how obvious.
