Build Thread Jr's 74 CJ5 "fix" and build as I go...
Nice progress, looks good!
Now to current time...
Just ordered a sway bar kit for the front, and will adapt some disconnects soon when I have the bar in hand.
Also need to bring the jeep down to the local driveline shop to check some angles for me. Think it's a bit off, around 40 MPH in 4th hear i have a bit of vibration. Tranny also looks like I may have gotten it slightly offset, so may need to readjust that. (Changed motor mounts without tranny attached so may have moved slightly)
And some skid plate builds, and little wiring issues, and I'm on the road. and OFF the road soon after! Can't wait to wheel my Jeep... Even if at the local OHV park only at first to test it all out.
~ Jr
Nice. Its good to know I'll be able to pick your brain a little when I do mine, whenever that may be. :rolleyes:
Nice :chug:
It's about time you got to work. :D
:notworthy:
Can't wait to see how the sway bar helps the lean in corners... wont let my wife drive it right now... scares me a little here and there too, so I'm not driving it much either. I know jeep leans, and know to keep them slow through corners, they're not race cars... but this is REAL flexy...
Can't wait to see it flex off road!
:chug::chug:
~ Jr
Your doing a great job :notworthy: funny how now days everything needs modifying to get it to work right.
Resurrection!!!
I'm tired of chasing wiring issues through rat nest(s) of wiring and adding on accessories with multiple batter connected power leads etc...
So I'm rewiring the whole jeep :eek:
1st time trying project like this, feel confident in wiring skills, but still not a pro electrical genius... Will be replacing the dash with complete custom build stainless steel dash, new gauges, new EZ wire harness with fuse box, and adding rock lights, and a few upgraded circuits for head-lights etc using 30A relays.
As always, while I have the roll bar off to get the dash off, I may do some upgrading / fixing on my column, under dash mechanics, and roll bar mounts (tie into the frame etc)
So here we go... Work will start this weekend.
Jr, sounds like you have a really good plan mapped out.What gauges are you going with? mech. or electric? I have been looking at the GPS based Speedo's.Kinda cool. Keep us updated with photos. :) mike
JR, based on other stuff I have seen you do he wiring should not be a problem for you.
Only thing I wish I did was run extra grounds into the cab when in installed my harness. I ended up adding them later. So maybe add one to the under dash and one to run to the rear for things like tail/brake lights and CB antenna.
Tell if you need a hand.
your defrost duct rocks!! I like it.:cool:
JR74CJ5,
As IO said that defrost rocks, did your brother weld up plates & tubes on the end for the tubes or machined other side? Nice & keep pictures coming, here is what I did for clean power in for accessories. SS tube with soldered ground to Bat-, 4g cable in to circuit breaker then to distribution block, then to CB, Stereo & amps, Cig lighter, USB power & right wheel video camera.
Thanks.
$150.00
  75.0%
