Leak identification
Leak identification
stoney bones
michigan
81 CJ7
258ci, mc2100 ,SR4 trans, dana 300 Tcase, dana 30 front, amc 20 2 piece rear
mine looks like your top picture and I am taking mine to the shop to get the axle seal replaced. Yours looks much worse than mine
I realize that this is from another forum, however it does apply here as well.
Leak Identification
i would put money on it being your axle seal. not a hard job if mechanically inclined. i would recommend maybe checking and repacking your bearing while your in there.
What's the fluid? Gear lube vs brake fluid is quite different.
Take a closer look.
Take a closer look.
In my experience, gear oil has a distinctive FUNK :eek: to it that you'll know when you smell it. If it is brake fluid you'll noticed a drop in the fluid level in your master cylinder.
Best of luck
