LED speedometer lights
Turbogus
Old Time Jeeper
Albany, OR
'78 CJ 5 Renegade (Black Betty) Motor AMC 360, T150 trans, 20 tc, Dana 30 front and Dana 44 rear w/posi
'96 GMC K1500 Suburban (Big Blue Basterd) fully loaded with over $10k in options
Now that the carburator work is finally getting completed I'm moving on to other delayed projects. One easy one was to add LED bulbs to the indicator lights in the Speedometer housing. As I was removing the old radio for an updated one I had access to the back of the Speedomter and it turned into just a simple plug-n-play. What a difference, especially on the dim turn signals. Not my idea though, a lift of the lynch lid to Gary R. Here's the link;
LED Dash Lights - JeepForum.com
I really dig these too, and I was so impressed with the brightness and cool to the touch feature, I put LEDs behind the meters in my trusty old Cobra 142GTL.
<~~ of course it helps to have everthing else completed under the dash before you swap these out. :rolleyes: Go figure, I had to reconnect the speedomter cable when at first I thought I'd have to remove it for this upgrade, wound up disconnecting the LED for the High Beam indicator. Had to dive under the dash again to reconnect it, would be easier iof I weren't a Hurdy Gurdy Man (<~ Donovan)
