license plate
license plate
reptile610
st. clair shores, MI
1982 CJ7: 151cu iron duke/ sr-4 trans/ dana 300/ dana 30 front amc 20 rear 3.73 gears.
Something I saw done on a TJ Rubicon was wrap the plate around the rear corner just below the tail light were the bracket would place it and screw it flush to the corner. No edge sticking out to grab you or whatever, it was realy clean and have thought of doing it myself.
wouldn't that allow for water to get in there and rust it??? also would it be illegal considering from the the rear you wouldn't be able to read the full plate?
The one in the pic is an extra one I have that I don't need if you want it you can have it. Send me a PM with your info and I will send it to you.
Probably but this guy is a desert wheeler and would see little rain, I did not look close to see if it was sealed or maybe had a small air gap?
I have a license plate braket if you want it pay for the ride and you can have it.
It's in the mail you should see it thrusday
